1. gamezz's Avatar
    I have a question if there is any tutorials for google maps go to work with android auto app?
    06-12-2020 04:55 AM
  2. hallux's Avatar
    Not really. Once you open Maps it looks the same. You can do voice commands to initiate navigation, and a voice command to cancel navigation. What more are you looking for?
    Also, this is not a user research topic, we'll get this moved. @mustang7757 or @B. Diddy
    mustang7757 and B. Diddy like this.
    06-12-2020 05:25 AM
  3. gamezz's Avatar
    Im looking for traffic and speed infos to work with my car. With google maps it's ok i can connect. But with google maps go i cant connect the app. You maybe got ny tutorial for google maps go and android auto app.
    06-12-2020 06:15 AM
  4. hallux's Avatar
    For what it's worth - on Android Auto with regular Google Maps, I only see traffic and speed limit info if I'm actively navigating. If I just have the map interface showing I don't get that info.
    So Maps Go does not work as a maps app in Android Auto?
    06-12-2020 06:21 AM
  5. gamezz's Avatar
    i dont know im asking you if it works.
    06-12-2020 06:41 AM
  6. mustang7757's Avatar
    [Moved to general help Forum]
    B. Diddy likes this.
    06-12-2020 08:57 AM
  1. I have a problem with voice recorder app!!!!
    Last Post: 06-13-2020, 10:13 AM
  2. Windows 10 not recognising Android phone?
    Last Post: 06-13-2020, 01:20 AM
  3. Any tricks to getting "New line" deals on Verizon?
    By aweber1nj in forum General Carrier Discussion
    Last Post: 06-12-2020, 12:28 PM
  4. Camera not working?
    Last Post: 06-12-2020, 05:58 AM
  5. Xbox One Controller lag on Samsung Galaxy Tab A?
    Last Post: 06-12-2020, 05:13 AM
