1. JadenCR2034's Avatar
    I have a droid turbo original phone and some apps no matter what I do I kill them with other apps I force stop them nothing works soon after I discover they are running again continuously not all apps do this but a handful do it's getting really annoying.I've even been in the developers menu trying to find the right settings to keep them turned off till I want to use them.Please help anyone know how I can keep them shutoff or is it a waste of time trying?
    06-13-2020 09:20 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum for more specific traffic.
    Some system apps or preinstalled apps are designed to open on their own for various reasons -- perhaps they're essential to the system, or perhaps that's just how the phone manufacturer coded it because the app developer paid them money to have the app active. What apps are you referring to?
    JadenCR2034 likes this.
    06-13-2020 10:32 AM
  3. JadenCR2034's Avatar
    Actually they are all apps I've installed from Google play.
    06-14-2020 01:13 AM
  4. mustang7757's Avatar
    Google apps like play store need to run process again , location, WiFi, etc can disable some permission but some apps might not work properly
    Laura Knotek likes this.
    06-14-2020 08:45 AM
  5. Mooncatt's Avatar
    Android is designed to keep memory filled. If you arbitrarily kill apps, the OS will always initiate either those apps or different ones to fill it again. They stay dormant in the background, not using any processing power, but are able to be immediately called up when needed. This helps improve battery life and speeds up multitasking. It's best to not kill off apps arbitrarily, unless you have a specific problem with a rogue app.
    tube517 and Laura Knotek like this.
    06-14-2020 09:13 AM
  6. JadenCR2034's Avatar
    Thanks for the help.
    06-14-2020 12:53 PM
  7. keepkid's Avatar
    Because they work as a service/
    06-24-2020 08:03 AM
  1. Android Backup w/ Encrypted SD Card.
    By shrilllying in forum General Help and How To
    Last Post: 06-14-2020, 08:25 PM
  2. Is my Moto X4 dead?
    By ScttLee184 in forum Ask a Question
    Last Post: 06-14-2020, 07:54 PM
  3. Replies: 3
    Last Post: 06-14-2020, 02:17 PM
  4. Can anyone help me unlock my SIM card?
    Last Post: 06-14-2020, 08:24 AM
  5. Replies: 1
    Last Post: 11-02-2014, 10:43 PM
