Originally Posted by
cdmjlt369 I just switched to straight talk. I have an LG journey, ($40 phone). Will a $100- $150 phone get better reception?Thoughts please. Thanks in advance.
Here’s the problem with America Movil and it’s USA MVNOs to answer your question. It owns Tracphone MVNO and it’s related brands like Straight Talk MVNO too. Straight Talk sells the hardware with included SIM card optimized for a specific carrier.
https://en.m.wikipedia.org/wiki/TracFone_Wireless
I recently was setting up a Straight Talk account which I learned more than I ever cared too. Original phone was a Straight Talk Alcatel something from couple years ago running a SIM on Straight Talk MVNO T-MOBILE network. I pulled the SIM and put in a newer Alcatel factory unlocked device that ran ok but data coverage and reception wasn’t as good. I switched to different factory unlocked Android which had even worse data coverage and reception. Using a signal tester, AT&T or VZW was the better choice based on nearby towers. I personally use AT&T postpaid account so I requested a new programmed Straight Talk AT&T MVNO SIM and two days later popped SIM in the phone.
All was OK in my tester phone but when I moved back into the newer factory unlocked Alcatel, back to garbage. I went and bought another TCL branded Straight Talk device, and inserted that newer SIM and even worse.
I called Straight Talk customer service. The new phone model I got was optimized for VZW so my Straight Talk AT&T SIM wasn’t playing nicely. Using the Straight Talk VZW MVNO SIM included with the phone in the box and switching over fixed the problem.
You literally have to let them know which carrier (AT&T, VZW or T-Mobile) for your primary network you want first. Then let Straight Talk sell you that phone optimized for that network.
Also, Cricket is AT&T owned and MetroPCS is T-Mobile owned. Not as complicated as the Straight Talk and it’s related Tracphone system.
