Shooting in Raw A51
May 28, 2020
Hello, I recently acquired the Galaxy A51 and I wanted to be able to get raw files out of it. I can use the Lightroom app to get raws, but that's limited to 12 mp and I can't use the macro, or wide-angle. Is there any app I can use other than Lightroom to get raw files? Preferably one with a good Pro mode, as the pro mode on the A51 is terrible.
Is there maybe something I can install that will add a better pro mode to the camera app, or let me shoot in raw?
Thanks
You can only use the main lens for Raw. As for apps
Adobe Lightroom (free)
ProCamera (7,99€)
RAW+ (free + 4,99€ unlimited shots)
VSCO (free)
Halide Camera (5,99€)
Pro Cam 7 (5,99€)
ProShot (1,99€)
Unfortunately Samsung locks their camera down and 3rd party apps are unable to add RAW to the additional cameras. I don't even know of a single app that allows me access to the telephoto lens on my Note 8 or 9.
I've seen a couple apps that allow me to adjust the ISO beyond what Samsungs Pro mode can do but that's it. Other wise any 3rd party camera app I've tried has offered no advantage.
FahadsTech
