    Only when I am home and only when Bluetooth is on. I get a notification every minute. Reset nothing. Reminder is off. Help me!
    07-01-2020 11:20 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you see an actual notification icon in the status bar, or are you only hearing a tone?
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    07-02-2020 12:09 AM
  3. Segomil's Avatar
    Just the tone. A message flashes but not long enough to read and not every time.
    07-02-2020 08:15 AM
  4. Javier P's Avatar
    Welcome to the forums. Which phone do you have? It's possible that an app is detecting an available Bluetooth connection and sending that notification.
    07-02-2020 08:47 AM
  5. Segomil's Avatar
    Samsung j3. It only goes off when my phone is home. All my apps save three have notifications turned off.
    07-02-2020 10:04 AM
  6. Javier P's Avatar
    You can try the Nice Catch app to find out which app or system process is pushing that notification.
    https://forums.androidcentral.com/sh...d.php?t=983538
    Also, do you have Smart Lock enabled? It could be a notification after the phone detects a Trusted Location or Trusted Device.
    07-02-2020 10:11 AM
  7. Segomil's Avatar
    Just installed notify blocker. Nothing in the log still going off every minute.
    07-02-2020 10:45 AM
  8. Javier P's Avatar
    See if you still get the notification in Safe Mode.
    07-02-2020 10:48 AM
  9. B. Diddy's Avatar
    Try also Toast Source.
    07-02-2020 11:56 AM
  1. Pixel 4XL, is it worth it?
    By alarsen7 in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 09-11-2020, 07:28 PM
  2. When I'm on the phone with someone, my phone wont lock?
    Last Post: 07-03-2020, 02:46 AM
  3. Why does the audio not go through my headset when I make a call?
    By Android Central Question in forum Samsung Galaxy Tab A 10.1 (2019)
    Last Post: 07-03-2020, 12:09 AM
  4. Can't take screenshot on my Samsung S8?
    By Joshsalvatore in forum Samsung Galaxy S8 & S8+
    Last Post: 07-02-2020, 11:15 AM
  5. Replies: 0
    Last Post: 07-02-2020, 08:20 AM
