    I know this probably does not belong here but trying to post a question on the google forum i have no idea how to do that.
    I have a Samsung A70 and i do sync my contacts. In the past when i changed a contact phone number or address it would sync with my google account, now when i change a contacts phone number on my mobile phone Google reverts it back to the old phone number, i am just wondering if there is a solution to this ?
    Regards
    07-21-2020 12:20 PM
  2. mustang7757's Avatar
    Strange , have you tried log out your Google account then back in ?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    07-21-2020 01:34 PM
  3. BergerKing's Avatar
    Perhaps a glitch has occurred, and the phone needs a simple reboot or a refresh. Its worth a try, as well. When I swapped to my J2, I was having a problem with syncing new numbers with a Note 9 on the same account. I ended up doing a reboot that cleared things up. Things get glitchy, sometimes.
    mustang7757 likes this.
    07-21-2020 06:39 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! First, are you certain the contact you're editing is saved to your Google account, or could it be one that's saved to the local Phone account? Is it possible you merged duplicate contacts (one that was in your Google account, the other in your Phone account)?
    Also, go to Settings>Accounts​, select your Google account, then make sure there are no Sync Errors listed.
    07-21-2020 09:24 PM
  1. Samsung Galaxy Note 3 - Lineage 16 and Galaxy Apps, can I get the apps with a custom ROM?
    By Intercity329 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 07-24-2020, 06:17 AM
  2. Hi, Newbie here! I have a Samsung S10+ and wonna get into photography with it...
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 07-23-2020, 01:01 PM
  3. How do I fix InCallUI problem?
    Last Post: 07-21-2020, 09:51 PM
  4. Problem to disable "Google duo" app.
    By Emacook in forum Google Duo
    Last Post: 07-21-2020, 09:48 PM
  5. Hi, Newbie here! I have a Samsung S10+ and wonna get into photography with it...
    Last Post: 07-21-2020, 01:30 PM
