1. normanp's Avatar
    What is the WLAN calling feature on the Lenovo Vibe K5 Plus A6020A46 and how do I use it to make phone calls? (Note: It's WLAN calling and not WiFi calling). I've enabled it, there's a LAN available, but I still cannot figure how this feature works. Anyone with the same phone have any idea? I attached screenshots below? Thanks.
    What is the WLAN calling feature on the Lenovo Vibe K5 Plus A6020A46 and how do I use it ?-screenshot_1.jpg
    What is the WLAN calling feature on the Lenovo Vibe K5 Plus A6020A46 and how do I use it ?-screenshot_2.jpg
    07-23-2020 07:13 AM
  2. anon(10614692)'s Avatar
    It's WiFi calling
    07-23-2020 07:43 AM
  3. normanp's Avatar
    There aren't any options once it's enabled...
    07-23-2020 08:42 AM
  4. hallux's Avatar
    If you enable the option, connect to a good WiFi network and try to make a call does it use the WiFi or cellular?
    WLAN is another way of saying WiFi...
    07-24-2020 12:57 PM
  1. [7/23/20] Tab A 10.1 2019 (Wi-Fi only) Now with Android 10 and One UI 2.1.
    By j_hansen in forum Samsung Galaxy Tab A 10.1 (2019)
    Last Post: 09-06-2020, 02:23 PM
  2. Replies: 8
    Last Post: 07-24-2020, 11:31 AM
  3. What is inCalAgent?
    Last Post: 07-23-2020, 09:08 AM
  4. How do you transfer a voice recording from your samsung j1 to a usb?
    Last Post: 07-23-2020, 08:38 AM
  5. Daily News - news app now for free on Gear S3
    By melbon88 in forum Samsung Gear S3
    Last Post: 07-23-2020, 05:39 AM
