1. andreaalvise's Avatar
    Hi all ! I tried to my modify a post of mine,and then I clicked saved.But what does it means ? Where I saved it ? Did I accidentally shared my post with my contacts or not ?
    08-10-2020 02:40 PM
  2. hallux's Avatar
    When you edit a post and click to save changes it simply saves the changes to that post so others on the forum can see the revised content. This does nothing to save it to the device from which you're posting.
    08-10-2020 02:47 PM
  3. andreaalvise's Avatar
    But did I accidentally share something with my phone contacts or not ?
    08-10-2020 03:10 PM
  4. hallux's Avatar
    Why would you think you did?
    08-10-2020 03:51 PM
  5. Javier P's Avatar
    No, don't worry.
    08-10-2020 03:56 PM
  6. B. Diddy's Avatar
    All you did was edit your post.
    08-10-2020 06:21 PM
  1. Is the Ultra hump a turn off?
    By donebrasko in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-10-2020, 08:42 AM
  2. Why does api 3 on my phone and i cant reset but the house coputer does not
    Last Post: 08-10-2020, 05:58 PM
  3. Replies: 5
    Last Post: 08-10-2020, 02:56 PM
  4. what are the green dots on my Samsung galaxy 11a?
    Last Post: 08-10-2020, 11:23 AM
