1. jonnyzlio's Avatar
    Edit: it turned out its not there because I'm using Microsoft launcher which didn't allow it, thank you all for your help 🙂
    Q: Did Samsung remove the ability to pull down the notification bar by swiping down anywhere in the home screen?
    08-19-2020 07:40 PM
  2. mustang7757's Avatar
    Make sure it enable, one press home screen on empty space then tap hone screen settings then toggle on for swipe down notifications panel
    08-19-2020 07:42 PM
  3. cardboard60's Avatar
    correct me if I'm wrong.
    I was told there is a icon
    08-19-2020 07:56 PM
  4. jonnyzlio's Avatar
    Thank you for pointing that out. I went to try it just to find out that my custom launcher wasn't allowing it, I uninstalled it and now it's working!
    mustang7757 likes this.
    08-19-2020 08:49 PM
  1. 5G on TMobile - New Note 20 Ultra - Slow Speed
    By tipopilota in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-22-2020, 05:59 PM
  2. Issues with Note 20 Ultra 8k recording
    By umar sultan in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-20-2020, 01:00 PM
  3. Inconsistent notification tones
    By tommy_clutch in forum General Help and How To
    Last Post: 08-20-2020, 12:59 PM
  4. Trade in ?
    By ezdoit in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-20-2020, 12:23 PM
  5. The Note 20 is a good buy (in my opinion)
    By Kendahl Titcomb in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-19-2020, 11:59 PM
