1. DotLGphn's Avatar
    I have a Alcatel Fierce 4 5056N cellphone and I want to stop predictive text substitutions when I type a word that I meant to type. Is there a way to stop this from happening. It's really frustrating.
    09-03-2020 05:52 PM
  2. B. Diddy's Avatar
    Which keyboard app are you using? Have you already looked at its settings menu?
    09-03-2020 06:54 PM
  3. mustang7757's Avatar
    What android version it's on? It's about 4 years old. See if other keyboard can be used.
    09-03-2020 07:37 PM
  4. ManiacJoe's Avatar
    Check your keyboard settings. If you want to turn off the automatic word replacement and go only with manual replacement, the feature to turn off is often called "auto-correct" (tied to the use of the space bar).
    DotLGphn likes this.
    09-04-2020 03:38 AM
  5. DotLGphn's Avatar
    English (US) Android Keyboard
    It is old! But it still works. It's a 6.0.01 Android. I also have the option to use "Bitmoji" and Google keyboards.
    Thank you! Found it! Here's what I did: I went to Settings, Android Keyboard, Text Correction, and turned off "Auto-correction". I guess "Predictive Texting" shows my age... LOL. That's what was used on the old, old, flip phones (and before "flipping" was heard of on cellphones).
    1. How do I stop "Predictive Texting" on my Alcatel Fierce 4 Phone?-autocorrect-settings_alcatel-1-.png 2.How do I stop "Predictive Texting" on my Alcatel Fierce 4 Phone?-autocorrect-settings_alcatel-2-.png
    09-05-2020 04:08 PM
  6. mustang7757's Avatar
    It may work but that will change going forward as more apps won't be compatible.
    09-05-2020 05:43 PM
  7. DotLGphn's Avatar
    Well, that is true, but by then I'll need a new phone anyway! This one is old... but still works. Thank you for your input.
    11-28-2020 11:01 AM
  8. mustang7757's Avatar
    It's going happen sooner then later , it's already 5 Android versions behind. Your welcome!
    11-28-2020 11:29 AM
  1. Replies: 16
    Last Post: 09-04-2020, 04:00 PM
  2. I can't update my phone once reverted back to stock firmware after rooting.
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 09-03-2020, 07:55 PM
  3. Will a verizon unlocked moto z2 force work on at&t
    Last Post: 09-03-2020, 07:00 PM
  4. How long does it take for google play services to update?
    Last Post: 09-03-2020, 04:32 PM
  5. I can't update my phone once reverted back to stock firmware after rooting.
    Last Post: 09-03-2020, 04:13 PM
