1. pj737's Avatar
    Was wondering if someone could help me here with what is likely an odd request. I am with AT&T and own a Galaxy Note 20 Ultra and have a Microsoft Surface Duo arriving later today. I would like to have my one phone number on both phones. AT&T offers a service where you can have one phone number on a phone and the same phone number on a device like a watch or tablet. But they do not allow syncing of everything between two phones.
    The goal is to have my Note 20 and Surface Duo become "one" phone; sort of like a clone. I am intrigued by the ability to have a specific phone with me that best accommodates my needs at that time. For example, if I'm going on a hike or to the store I would bring my Note... if I am going to the park to do some company work, I'd bring the Duo. But I would want the phones to basically sync everything so that anything done on one phone would replicate on the other phone.
    Things like email, calendar, notes, browsers, photos, etc all sync between android phones and devices. Where I would need syncing is between phone call logs and SMS/MMS messages (texting). Not just syncing but if my Note receives texts and I send texts from the Note, all the received and sent texts would show up on my Duo. Same would go for call log, voicemail, etc.
    Does anyone know how to accomplish this set up so it's functional and practical? I believe Google Voice may be an option but I am not sure if it achieves the above goals or how to go about getting there if it is possible.
    Thank you very much for any feedback!
    09-10-2020 06:04 PM
  2. L0n3N1nja's Avatar
    To my knowledge what your asking is impossible but I would love for someone to come on here and prove me wrong.
    09-10-2020 07:45 PM
  3. B. Diddy's Avatar
    I'm pretty sure Google Voice will sync the call log and messages, as long as you're looking in the Google Voice app. (The call logs in the native Phone app won't sync, though.)
    tony bag o donuts likes this.
    09-10-2020 09:24 PM
  4. tlc264's Avatar
    I use Google voice to accomplish this. I have it on my phones and tablets, and my texts and phone calls sync.
    B. Diddy and burrzoo like this.
    09-10-2020 09:31 PM
  5. methodman89's Avatar
    If you are with Tmobile, use the Digits app from Tmobile and you can do what you're wanting.
    09-11-2020 06:28 AM
  6. me just saying's Avatar
    work around is as already suggested. get a google voice and have all calls forwarded to real number. this way you can have all the info available in the google voice app (or whatever they are using these days). the only downside, is you will have to give all your contacts your new number :-)
    09-11-2020 10:28 AM
  7. hallux's Avatar
    Port the current number to Google Voice (https://support.google.com/voice/answer/1065667?hl=en) and have AT&T issue a new number for the phone. Then get a second number for the second phone and link both numbers to Google Voice. People still call/text the old number but it goes to both phones.
    me just saying likes this.
    09-11-2020 10:37 AM
  8. me just saying's Avatar
    porting works :-)
    09-11-2020 10:40 AM
  1. Best phones/SoC for spotty rural areas?
    Last Post: 09-10-2020, 10:54 PM
  2. Why instagram menu icons are appearing on the bottom of my phone?
    Last Post: 09-10-2020, 10:29 PM
  3. I can't find the clipboard on my zte phone
    Last Post: 09-10-2020, 10:27 PM
  4. I've lost my phone icon from my home screen my phone is an Alcatel
    Last Post: 09-10-2020, 03:18 PM
  5. Replies: 1
    Last Post: 09-10-2020, 12:12 PM
