New Samsung alert! Score a Galaxy S21 5G for as little as $99 right now
Unable to enter the recovery mode to do factory reset, Stuck in Odin Mode
- I thought it would be good to post this question in this general forum instead of going to the forum for this specific model (Galaxy Core)
I have an older Samsung phone model Galaxy Core SM-G360F which I didn't use for several years. Today I wanted to use it again, but I can't remember the password that I set up on it years ago. I decided to do a factory reset, but alas, for some reason I am unable to get the recovery menu with the usual key combination: Volume UP + HOME + Power On. If I keep these three keys pressed, the phone turns on and displays this menu:
Please note that there is nothing below this text except the Samsung's usual logo. Here is a picture where I tried to catch the entire mobile phone's screen:
I don't know why this "Odin Mode" appears instead of the recovery mode from which I could select Factory reset?
If I keep the following 3 buttons pressed: Volume Down + HOME + Power On, I will get the download screen like this:
and pressing Volume UP leads me to something that also seems to be some form of Odin Menu. But I can't choose Factory reset from that menu either. If I press Volume Down at that point the phone just restarts itself.
Does anyone know how to get into the Recovery mode by using the phone's buttons only?10-04-2020 08:58 PMLike 0 - Choose restart , then before screen comes back on to restart hold volume up/power button sane time , if It takes you to a bot just hold sane buttons momentarily again then should be in recovery10-04-2020 09:04 PMLike 0
- When I select Restart, then hold Volume Up + Power button, it just boots normally and asks for the password (which I forgot). That combo doesn't bring up any specific menu.10-04-2020 09:12 PMLike 0
I am thinking.. perhaps years ago I tried to flash this phone using Odin and it somehow "remembered" that and now expects to continue with that operation? No idea if that's the case, but I think I might have tried something like that. I didn't actually flash the rom. I continued to use the phone as it is from the factory, but maybe my attempt was somehow remembered?10-04-2020 09:28 PMLike 0 -
- Just tried it: Turned the phone off. Then held Volume UP + Power button. This doesn't bring up any menu, just boots normally and leads into the Android itself.
I am thinking.. perhaps years ago I tried to flash this phone using Odin and it somehow "remembered" that and now expects to continue with that operation? No idea if that's the case, but I think I might have tried something like that. I didn't actually flash the rom. I continued to use the phone as it is from the factory, but maybe my attempt was somehow remembered?10-04-2020 09:32 PMLike 0 -
- I mean it just loads the Android OS as usual, without giving me any special menu to choose from. It's as if I just pressed the Power On button alone and switched on the phone in the most regular way. But since the current Android has a set up password (which I forgot), I can't use it. I can't get past the "enter the password" screen.
Is there any other way to remove the password except the factory reset? Btw. I think this phone uses Kitkat.10-05-2020 06:55 AMLike 0 - I mean it just loads the Android OS as usual, without giving me any special menu to choose from. It's as if I just pressed the Power On button alone and switched on the phone in the most regular way. But since the current Android has a set up password (which I forgot), I can't use it. I can't get past the "enter the password" screen.
Is there any other way to remove the password except the factory reset? Btw. I think this phone uses Kitkat.10-05-2020 09:27 AMLike 0 -
Enable USB Debugging on your device from Settings -> Developer Options. If Developer Options is missing or not enabled, then go to Settings -> About Phone and tap on Build Number for about 7-10 times.
Unlock Bootloader as installing CF Auto Root, Custom Firmware, Custom Recovery, and other patch files require an unlocked bootloader. Otherwise, it may brick your device.
Kill Samsung PC Suites like Samsung Kies etc. So, they won’t interfere with the Odin Downloader.
The only other alternative would be to take the phone to a mobile service and ask them to try to flash it. But it's doubtful whether they would be able to do anything different than what I can do?10-06-2020 07:42 AMLike 0 - All the phones I flashed I didn't need to save usb debugging enabled . You'll need to find your exact model and region for your device .
The tools for the firmware can download at XDA Forums called samfirm latest or frija and extract them with 7zip.
Make sure your in download mode for this and use the latest Odin first otherwise older Odin , when connect to computer it shows Com port example 9 in odin box .10-06-2020 09:50 AMLike 0 - All the phones I flashed I didn't need to save usb debugging enabled . You'll need to find your exact model and region for your device .
Hi mustang7757, sorry about resurrecting this old thread, I couldn't find the necessary time to deal with this problem when this thread was started, but now I would like to try to see what can be done about it.
As for Samfirm or Frija, both of them require the CSC code, but the problem is that I am unable to find that code for this phone because it won't let me get past the "enter the password" screen. As far as I know, one can see the CSC code by dialing *#1234# or by going to Settings -> About phone -> Software settings, but I am not able to do any of these things.
The only information about this phone that I know is what is written on the sticker below the battery. This is what I can see there:
Attachment 329214
Could you please help me with finding out the CSC code and the correct firmware for this phone? I already downloaded some firmware from website called a2zrom.com, and its file name is G360FXXS1BQA5_G360FAUT1BOI1_G360FXXS1BQA2_HOME.tar .md5. It appears to be some kind of generic firmware, but I am not sure if it would be safe for flashing my phone?11-26-2020 09:59 AMLike 0 - Hi mustang7757, sorry about resurrecting this old thread, I couldn't find the necessary time to deal with this problem when this thread was started, but now I would like to try to see what can be done about it.
Attachment 329214
Could you please help me with finding out the CSC code and the correct firmware for this phone? I already downloaded some firmware from website called a2zrom.com, and its file name is G360FXXS1BQA5_G360FAUT1BOI1_G360FXXS1BQA2_HOME.tar .md5. It appears to be some kind of generic firmware, but I am not sure if it would be safe for flashing my phone?11-26-2020 10:29 AMLike 0 - 11-26-2020 12:07 PMLike 0
- This is the next screen which I get when I press Volume Up (Continue). It looks just like the screen I'm getting when I press Home + power on + Volume Up in the first place, but it has also the android robot below saying "downloading... do not turn off the target".
I don't see the firmware info on this screen either.11-26-2020 12:40 PMLike 0 - 11-26-2020 12:43 PMLike 0
Can this phone be flashed at all?11-26-2020 12:45 PMLike 0 - No, that's the problem. I get the same text in both cases, when I press Power on + Home + Volume Up AND when I press Power on + Home + Volume Down (then volume Up to continue). In both cases it doesn't give me the option to choose Factory reset.
Can this phone be flashed at all?Laura Knotek likes this.11-26-2020 12:50 PMLike 1 - By the way, I bought this phone in a store that specializes for mobile phones, and it wasn't tied to any particular mobile service (I bought a sim card later at a newstand).11-26-2020 12:51 PMLike 0
Serbia (Telekom) (TSR)
Serbia (Telenor) (MSR)
Serbia (VIP) (TOP)
When I put any of them for CSC code in Samfirm or Frija, they can't find anything.
Perhaps it was intended for some other country or region, but ended up being sold in Serbia? I don't know...
Would it be safe to flash it with this generic firmware downloaded from a2zrom.com? The file name is G360FXXS1BQA5_G360FAUT1BOI1_G360FXXS1BQA2_HOME.tar .md5.11-26-2020 12:56 PMLike 0 - You probably could flash like the UK firmware which is a common one on international version, but we don't know how well it work with your current carrier11-26-2020 12:58 PMLike 0
United Kingdom (VIR)
United Kingdom (BTU)
United Kingdom (EE) (EVR)
United Kingdom (H3G) (H3G)
United Kingdom (O2) (O2U)
United Kingdom (Vodafone) (VOD)
United Kingdom / Ireland (XEU)11-26-2020 01:06 PMLike 0 -
- Forum
- Android Central Community
- General Help and How To
the LG V60 dual screen case
By BobbyD1981 in forum LG V60 ThinQReplies: 10Last Post: 10-21-2020, 03:27 PM -
Does anyone know any possible way to connect the Lg Stylo 6 to a tv with an hdmi cable?
By Android Central Question in forum Ask a QuestionReplies: 17Last Post: 10-11-2020, 04:40 PM -
Mirroring to av input?
By Beachin22 in forum Samsung Galaxy S9 & S9+Replies: 0Last Post: 10-04-2020, 05:19 PM -
Are The Asurion 3-Year Warranties on Amazon Too Good To Be True?
By consultant1027 in forum Buyers GuidesReplies: 2Last Post: 10-04-2020, 03:19 PM
