1. DeanoEssex's Avatar
    Why does my Android v9 - PX5 car stereo just keep saying "Connecting saved, connecting saved, connecting saved, connecting saved... Disabled!" I have reset my device, i have run an extension so the Hub 3 is 5 feet away from my car (outside) and all i get is this stupid message when i am trying to connect to my wifi. My car will not connect. Any genuine help will be massively helpfull.
    10-05-2020 01:37 PM
  2. mustang7757's Avatar
    Can you reset your car radio? Reset button?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    10-05-2020 02:00 PM
  3. DeanoEssex's Avatar
    A big thank you to Mustang7757 for the link to join.. I am reposting my question here :-)
    @mustang7757 I did do a full system reset but it still refuses to connect.
    Original question:
    Why does my Android v9 - PX5 car stereo just keep saying "Connecting saved, connecting saved, connecting saved, connecting saved... Disabled!" I have factory reset my device, i have run an extension so the Hub 3 is 5 feet away from my car (outside) and all i get is this stupid message when i am trying to connect to my wifi. My car will not connect. My phones connect just fine... Any genuine help will be massively helpfull.
    mustang7757 likes this.
    10-05-2020 02:26 PM
  4. methodman89's Avatar
    Did you try 2G and 5G off the router or just 5?
    10-05-2020 02:28 PM
  5. DeanoEssex's Avatar
    It was on my 2.4Ghz wifi. It will not detect my 5Ghz. It used to work just fine on my wifi but all of a sudden it stopped. That is what prompted me to reset my device.
    10-05-2020 02:39 PM
  6. mustang7757's Avatar
    [Merged your original thread to prevent parallel discussion]
    Hi, welcome to AC , you welcome!
    I also made you the post owner
    DeanoEssex likes this.
    10-05-2020 02:47 PM
  7. B. Diddy's Avatar
    Welcome to Android Central! I also moved this out of the Introductions forum to the General Help forum.
    10-05-2020 06:16 PM
  8. Tom Panek's Avatar
    I have a Moto E4 with a similar problem with my phone and my wife's phone, which is the same as mine . After many hours trying to figure it out I logged onto my Netgear router and changed one setting.
    Under Basic settings I went to Router MAC address section and changed from Use default address to use this address, which is the MAC address of the router.. Applied the change and both phones connected without problem and are still connected.
    Hope this helps others.
    B. Diddy likes this.
    10-10-2020 10:00 AM
  9. B. Diddy's Avatar
    Welcome to Android Central, and thanks for the tip!
    10-10-2020 12:21 PM
  1. com.android.phone issue on Note 20 Ultra
    By BarneyRebel in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 11-01-2020, 09:11 PM
  2. Replies: 2
    Last Post: 10-06-2020, 11:10 PM
  3. Cannot connect both Skullcandy earbuds to Pixel phone
    Last Post: 10-05-2020, 11:34 AM
  4. Contacts not getting saved up in Android phone
    Last Post: 10-05-2020, 01:14 AM
  5. Why wont my camera or flashlight open, says their being used by another app?
    Last Post: 10-04-2020, 10:01 PM
