Predictive text between apps
I need to show two things with Swype predictive text.
The first is that Swype will use predictive text between apps. So if you use a word in app A Swype will suggest the same word in app B. Specifically between chrome and and Facebook messenger.
The second is that Swype will learn if you only use a word in swiping a URL. Again Facebook messenger is really the issue, that you don't have to talk to someone in messenger for the word to be suggested.
Thank you.
Re: Predictive text between apps
You'll need to find a different keyboard app. Swype was discontinued 2 years ago.
I use SwiftKey and Gboard, and both work well for me.
Originally Posted by
Laura Knotek You'll need to find a different keyboard app. Swype was discontinued 2 years ago.
SwiftKey is a really good app that does let you swipe. It's very intuitive.
