1. RedJeep20's Avatar
    I just received my SanDisk dual drive USB type-c 32 gig file storage. It came with absolutely no instructions. I was able to insert it and the phone is seeing the mounted device. Do I need to download anything. All I want to do is transfer some of my photos over to this portable device. Any help would be greatly appreciated. TIA
    ***Edit: Currently, I have a Galaxy S9+***
    Attached Thumbnails SANDISK Dual Drive USB Type-C (Help please)-20201017_131014.jpg
    10-17-2020 03:14 PM
  2. B. Diddy's Avatar
    Which phone do you have? You should be able to use it as a conventional external storage device. Use any file manager app to copy your files to that drive. If your phone's stock file manager is hard to use, then try Files by Google (in the Play Store) or Total Commander.
    Laura Knotek likes this.
    10-17-2020 07:22 PM
  3. RedJeep20's Avatar
    Thanks... I'll download it & give it a go. 👍
    B. Diddy likes this.
    10-17-2020 08:10 PM
  4. RedJeep20's Avatar
    Got it all set up, thanks for the help. I guess I expected to just plug it in and have it automatically launch an install menu. The solution that I needed was actually listed on the packaging... I just didn't see it.
    MEMORY ZONE! Worked great. Thanks again.
    Yesterday 10:09 AM
  1. Strange USB File Transfer Problem
    By PowrDroid in forum Google Nexus 7 Tablet (2013)
    Last Post: Today, 12:37 PM
  2. Lg v60 dual screen case replacement
    By Android Central Question in forum LG V60 ThinQ
    Last Post: Yesterday, 11:13 AM
  3. How to use that little USB transfer from device to device?
    By Super Spartan in forum Google Pixel 5
    Last Post: 10-18-2020, 07:16 AM
  4. Lg v60 dual screen case replacement
    Last Post: 10-17-2020, 10:31 AM
  5. How to use that little USB transfer from device to device?
    Last Post: 10-16-2020, 09:25 PM
