How to get rid of this Volume Bar that can not be turned down?
Pcrcol
Active member
Dec 30, 2014
25
I have a Galaxy S8 on Android 9, and I have this extra volume bar that I've never seen before.
It does not go down and I want to remove it.
Here is a screenshot: https://i.imgur.com/S4frxgs.jpg
Javier P
Ambassador
Feb 21, 2014
19,480
3
Do you have the Accessibility Menu enabled? Go to your accessibility settings and see which options are enabled in there.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
My suspicion is that slider can't be completely silenced, because it's the Accessibility volume -- Accessibility features for the visually impaired wouldn't be very useful if they were completely silenced. It's probably only for those Accessibility features that speak out loud.
