1. Larsianer's Avatar
    Hi, are there any guide of how i do flash the bios, or how i do the hard reset, i have tryed with holding the power button, and volume up
    and release power button when the android screen comes, but it wont work, i have also tryed volume down.
    I think i need to change/flash bios, i also get a error when i try to update it, so am stuck
    Any advice?
    Lars
    10-19-2020 03:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Why do you need to hard reset? Is it frozen, or stuck in a bootloop? Did you forget your password?
    Just to be sure, you followed these steps exactly? https://www.hardreset.info/devices/bq/bq-aquaris-x2/
    10-19-2020 04:25 PM
  3. Larsianer's Avatar
    hi, it wont update, and it wont see the simcard- that hard reset link wont work, so i need to flash bios, are there any guide of how to flash the bios?
    am sure it will work if i flash the bios
    Thanks anyway
    10-20-2020 06:32 AM
  4. B. Diddy's Avatar
    In terms of update -- are you talking about a system update? That phone is a 2 year old budget/midrange phone, so it's unlikely that it's still getting any system updates (unless you know for sure from the company or from other owners that it's supposed to get one now).
    For the SIM card issue -- have you already tried cleaning out the SIM reader using a can of compressed air, or trying a different SIM card (in case the problem is with the SIM itself)?
    10-20-2020 12:01 PM
  5. Larsianer's Avatar
    i tryed everything, am sure i need to flash bios, are there any guide of how to do it?
    10-20-2020 01:45 PM
  6. B. Diddy's Avatar
    10-20-2020 01:46 PM
  1. Didn't factory reset phone before sending to Asurion
    Last Post: 10-19-2020, 11:33 AM
  2. Recovery mode/factory reset works but safe mode doesn't
    Last Post: 10-19-2020, 02:40 AM
  3. Do I have game data after factory reset
    By Android Central Question in forum The Gamer's Lounge
    Last Post: 10-13-2020, 04:55 PM
  4. How do I factory reset a Nabi Dreamtab IN08A
    By Mark in forum Ask a Question
    Last Post: 02-10-2016, 07:29 AM
  5. How do I do a hard factory reset?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 04-12-2015, 05:17 PM
