1. jdub412's Avatar
    The fingerprint scanner only works about half the time and the phone restarts frequently. Should I try to fix this (and how) or get a new phone, and if so, which one? I was thinking of getting something used on black market phone. I use Verizon
    11-10-2020 08:33 AM
  2. B. Diddy's Avatar
    You've already tried using it in Safe Mode to see if it still restarts frequently? https://www.t-mobile.com/support/dev...e-lg-v40-thinq
    I'm going to assume you didn't mean an actual "black market" phone (which would be illegal and risky). You can find plenty of used phones on legitimate sites like eBay or Swappa.
    aximtreo and Laura Knotek like this.
    11-10-2020 11:30 AM
  3. belodion's Avatar
    Did the troubles start suddenly?
    11-12-2020 07:37 AM
  1. How can I remove or disable the Q Easter Egg on a Android 10?
    Last Post: 11-12-2020, 09:19 PM
  2. Why is my phone still working after a multiple hard reset?
    Last Post: 11-10-2020, 11:41 AM
  3. NOTE 10 - Phone Keeps Flashing "Same Update" Twice Everytime....
    By craige in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-10-2020, 11:40 AM
  4. Why wont my phone turn on when i hold down the button if it is charged?
    Last Post: 11-09-2020, 10:14 PM
  5. Why can't people hear me when I use my wireless headphones? How can I fix it?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 11-09-2020, 10:11 PM
