1. Sebine's Avatar
    I have an LG D415, six years old and finally retiring it
    I'm replacing it with a REVVL 5049W
    The problem is, the alarm sounds on the REVVL are trash.
    I want to copy over to the REVVL the Cello In The Morning alarm
    But I can't find *any* alarms or anything when plugging it into my laptop
    All I want is a bloody alarm sound that isn't grating to my nerves without jumping through 10 hoops to get it.
    11-19-2020 09:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If that's a preinstalled alarm tone on the LG phone, then it's in a protected system directory, and you can't directly access it unless you root the phone. See if it's available on Zedge.net.
    Laura Knotek likes this.
    11-20-2020 12:33 AM
  3. Sebine's Avatar
    How do you root a phone that old...?
    Zedge doesn't appear to even have anything with the word "cello" in it from the first page of "cello in the morning" search....
    11-20-2020 12:47 AM
  4. B. Diddy's Avatar
    I don't have any rooting experience myself, but XDA-Developers tends to be a better resource for that kind of thing: https://forum.xda-developers.com/lg-...droid-t3110257
    11-20-2020 01:53 AM
  5. spARTacus's Avatar
    You should be able to find most existing alarm and notification sounds on the web, with a bunch of searching.
    11-20-2020 05:10 AM
  6. Vemund's Avatar
    Hi, you can find it on Zedge here:
    https://www.zedge.net/ringtone/d2c2d...c-582365adb71b
    B. Diddy likes this.
    11-20-2020 06:42 AM
  7. Sebine's Avatar
    Admittedly, I probably should have clicked load more.
    But it was pretty late. Or early.
    Thanks Vemund.
    11-20-2020 09:34 AM
  8. Vemund's Avatar
    No problem, glad to help
    V
    11-20-2020 07:13 PM
  1. Who went from a pixel 2 to a 4a?
    By cbreze in forum Google Pixel 4a & Pixel 4a 5G
    Last Post: 11-21-2020, 04:24 PM
  2. If I uninstall Samsung Gallery from my PC will my photos remain in Samsung cloud?
    Last Post: 11-21-2020, 01:13 PM
  3. My phone updated to android 10 . Why are there duplicates of apps . ??
    Last Post: 11-19-2020, 09:33 PM
  4. Can my girlfriend control my s10 from here s20
    Last Post: 11-19-2020, 09:27 PM
  5. Texts from an email address
    Last Post: 11-19-2020, 05:46 PM
