Do not disturb keep turning on
Soulartist
Active member
Dec 9, 2019
26
U683CL phone
I've turned off everything I could find re:DND, but it keeps turning itself on. Please see attached. I've also tried the Do not disturb toggle app, but it won't work on this phone.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,535
6,115
113
What andriod version its running, this one of government funded phones ? They usually have all types of stuff on them like ads , apps can't be deleted . In that screen shot it mentions UI controls it somehow
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
It's still worth testing in Safe Mode, because these Lifeline phones (especially ones from UMX) are notorious for having preinstalled malware that automatically installs other apps without you necessarily knowing about it.
Soulartist
Active member
Dec 9, 2019
26
I didn't notice the DND did not turn itself on in safemode. In regular mode, I did notice the DND also gets turned on again when charging.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
That suggests some 3rd party app is causing DND to turn on. You might have to uninstall apps one by one until the problem goes away, since it can otherwise be difficult to pinpoint the culprit without having any prior suspicions.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,535
6,115
113
Haven't tried safemode because I recently reset to factory state and have only one downloaded app--Geico.
Even with Geico app as only app downloaded , long press it tap info > go to permissions do you see anything say enabled to modify system?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Glad the problem seems to be solved, but it's odd that Chrome or the Play Store would do this. Let us know if it comes back.
Soulartist
Active member
Dec 9, 2019
26
Hello again. Spoke too soon. After disabling those apps and two days of no DND -- it's back. How insidious that a system app, which it does not identify, would cause this nuisance.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
UMX is notorious for including relatively shady things in the system, like adware, so it might have to do with that. Not sure what else to suggest at this point, sorry!
Laila Nance
