1. anjana8iron's Avatar
    When I'm trying to install costom rom to it using twrp app, i had select some wrong img file (I do that when my phone was power on it's not recovery mode ). So now my meizu m2 phone is bricked it has bootloop and it only works on fastboot mode but "fastboot devices" command recognize phone and "getvar all" command work on it . Indeed other commands* didn't work on it (*the commands what I know). Actually when I'm trying to unlock bootloader it get that error (remote: unknown command) and trying to flash recovery it get that error (download partition recovery is not allowed ). So now I want to know how to fix my phone to reuse it.?
    11-30-2020 01:47 AM
  2. mustang7757's Avatar
    Hi welcome to AC!
    Try install the stock firmware again to get out of this , see if this link helps , otherwise try XDA forums.
    https://www.getdroidtips.com/stock-rom-meizu-m2/
    Laura Knotek and anjana8iron like this.
    11-30-2020 07:24 PM
  1. What is the issue for HONOR 8X phone?
    Last Post: 12-02-2020, 12:45 AM
  2. Replies: 2
    Last Post: 11-30-2020, 04:38 AM
  3. No matter how many times I apply for a password reset on this site, the email never comes.
    By Android Central Question in forum Site Feedback & Help
    Last Post: 11-29-2020, 10:43 PM
  4. Replies: 0
    Last Post: 11-29-2020, 10:40 PM
  5. How do i get my phone back from Google?
    Last Post: 11-29-2020, 09:58 PM
