1. huhphone's Avatar
    So I purchased this phone used thinking it was an HTC One M8. My only interest in the phone was to install a Lineage based rom. It worked. Every step of the unlocking and installation went as expected. And the phone claims to be an M8 in the "about" section in settings. But here's the strange part...
    I received it without the top plastic faceplate. After using the phone for a while I decided to buy a replacement plate on ebay. I received it and realized it was a completely different shape and didn't fit the phone. This spurred my curiosity so I started researching the M8 and none of the photos I found matched the phone I have.
    The back cover looks completely different. The bottom faceplate on the front of the phone looks different. The back cover doesn't detach and I can't access the battery. The front is a different shape. Even the holes on the back where the mic and speaker should be are different from the standard phone pics. The rear camera doesn't work so one possibility I thought of is that someone took the guts out of an original and put them in a replacement shell in an attempt to repair it. Or this could be a counterfeit phone. Or perhaps a prototype that wasn't commercially released.
    Were there different versions of the M8? Can anyone identify this phone? Why does it vary so much from a standard M8?
    https://i.ibb.co/SVB84rV/20201130-121328.jpg
    https://i.ibb.co/8jHJvRN/20201130-121347.jpg
    https://i.ibb.co/dtwsFT1/20201130-121403.jpg
    Compare to the true HTC One M8 below
    https://upload.wikimedia.org/wikiped...014%29.svg.png
    Attached Thumbnails Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-20201130-121328.jpg   Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-20201130-121347.jpg   Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-20201130-121403.jpg   Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-img_20201201_100108.jpg   Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-htc_model_name.jpg
    12-01-2020 10:12 AM
  2. mustang7757's Avatar
    Hi, welcome to AC!
    This what my HTC M8 looks like , yours has one flash on the back mine got 2Help solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-pxl_20201201_164236171.jpegHelp solve this mystery. What is the true identity of this phone that claims to be an HTC One M8?-pxl_20201201_164229412.jpeg
    12-01-2020 10:44 AM
  3. Rukbat's Avatar
    The specific model number on the label under the battery will tell you. (Or you can look for a site that lists model numbers by IMEI number and look it up.)
    Laura Knotek likes this.
    12-01-2020 12:01 PM
  4. mustang7757's Avatar
    Battery is sealed , that looks like fake M8
    Notice the camera on mime all the way on top.for depth is missing, and the 2 flash on side of main camera
    12-01-2020 12:05 PM
  5. L0n3N1nja's Avatar
    Looks like one of the budget HTC Desire phones to me, I wouldn't know specifically what model. Either it's a counterfeit phone(I've seen a few in the past) or it's had the wrong firmware installed on it if that's even possible.
    Either way, that isn't an HTC One M8 in the OPs photos.
    12-01-2020 12:22 PM
  6. B. Diddy's Avatar
    You might want to try multiple different system info apps, since some of them can see through false information better than others: https://www.androidcentral.com/best-...r-phones-specs
    12-01-2020 12:30 PM
  7. huhphone's Avatar
    EDIT: Posted before I saw the above reply. Thanks for the link. I'll try a few of those apps.
    Could someone post the specs of an official M8 so I can compare? Thanks!
    12-01-2020 12:31 PM
  8. mustang7757's Avatar
    Yeah probably a budget HTC phone .
    12-01-2020 12:31 PM
  9. mustang7757's Avatar
    Are there any adb/fastboot commands that would list hardware/software specs/versions? Or could you recommend an app I could install to grab all available hardware info about the phone and compare to a genuine M8? Thanks.
    I don't think you need to go that far , physically it's not the same.
    12-01-2020 12:32 PM
  10. B. Diddy's Avatar
    Check it out here: https://www.gsmarena.com/htc_one_(m8)-6074.php
    Laura Knotek and J Dubbs like this.
    12-01-2020 12:38 PM
  11. J Dubbs's Avatar
    Yep that's an HTC Desire..... I ordered 2 in a row back in the day from Amazon that were supposed to be brand new, both were used and neither worked. The only good thing about Amazon is their return process
    B. Diddy and mustang7757 like this.
    12-02-2020 08:19 AM
  12. mustang7757's Avatar
    I think it's pretty safe to say this is not a HTC M8
    J Dubbs likes this.
    12-02-2020 01:08 PM
  1. Replies: 13
    Last Post: 12-04-2020, 11:04 AM
  2. What is this notification on top left of screen?
    By bails97 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 12-01-2020, 05:53 PM
  3. how much time will my vivo v5 phone take to update
    Last Post: 12-01-2020, 12:31 PM
  4. To receive pictures from someone on chat
    Last Post: 12-01-2020, 12:25 PM
  5. Is it normal for apps to record calls without my consent
    Last Post: 12-01-2020, 01:51 AM
