1. livan0011's Avatar
    I bought a android headunit from this company called EONON model:GA2180A with android 10 and I had it for 2 days worked perfectly and one day I start up my vehicle and the unit is stuck on boot loop is there anyway I could fix this? They did told me to download a software update file on a usb to manually update it so idk if that could be a way to fix the boot loop because it was still stuck on boot loop after the update https://www.youtube.com/watch?v=BX3Gkai2C2U&t=5s there's the video for reference thanks in advanced if anyone has any ideas or if anyone has any experience with these android headunits
    12-15-2020 02:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! See if you can boot into Recovery Mode using the steps mentioned here: https://forum.xda-developers.com/t/h...d-kdl.3843295/. Then see if there's an option there to manually update the firmware via USB.
    12-19-2020 06:59 PM
  1. No Chromecast or Mirror with new Android 11
    By ahmed hanif1 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 02-27-2021, 08:43 PM
  2. Voicemail for 4a 5G on Verizon (not a Verizon phone)
    By kmcochran in forum Google Pixel 4a & Pixel 4a 5G
    Last Post: 01-05-2021, 02:02 PM
  3. HP Slate 21 re-install android
    Last Post: 12-19-2020, 07:50 PM
  4. Tecno Spark 4 Stuck in Bootloop URGENT!
    Last Post: 12-16-2020, 06:36 PM
  5. New to Android Central coming over from 10years at Crackberry
    By qphone in forum Google Pixel 4a & Pixel 4a 5G
    Last Post: 12-15-2020, 10:11 AM
