1. dangerousfen's Avatar
    Due to the awful stock camera on my Nokia 7.2, I've installed Gcam PX 4.3 7.2.014.
    It works very well indeed but I cannot find how to change storage from internal to external SD card.
    I would be grateful for any help in achieving this. Thanks.
    01-16-2021 04:29 PM
  2. Javier P's Avatar
    Gcam doesn't have an option to save photos in the SD card. You need to move them manually or try some apps from the Play Store that claim to do that, including Tasker. I haven't used any of them so I can't recommend you one in particular.
    dangerousfen likes this.
    01-16-2021 04:35 PM
  3. dangerousfen's Avatar
    Thanks Javier. Well, that's sorted then. It's not really that important so I'll just leave it as is.
    I guess I should have realised it myself as Pixel's don't have SD support.
    Gcam really does work superbly on my 7.2. The camera is certainly a big step up.
    Javier P likes this.
    01-16-2021 04:47 PM
  4. Javier P's Avatar
    Exactly, that's the reason why Gcam doesn't have SD support. I use Gcam as well with my OnePlus 7, in most situations it's much better than the stock camera.
    01-16-2021 04:58 PM
  1. Signal Messaging App on Galaxy Watch?
    By omelet1978 in forum Samsung Galaxy Watch
    Last Post: 02-03-2021, 04:14 AM
  2. Replies: 2
    Last Post: 01-16-2021, 10:48 PM
  3. QuickMemo+ on my LG G3 won't open
    Last Post: 01-16-2021, 02:28 PM
  4. Replies: 3
    Last Post: 01-16-2021, 12:30 PM
  5. "Turn on offline finding"
    By jimmyjam22 in forum Samsung Galaxy S10 & S10+
    Last Post: 01-16-2021, 12:15 PM
