I wasn't getting anywhere searching, so I came here.
What is happening is, I'll be using my phone like normal, & suddenly I will be returned to my home screen, with no icons, just wallpaper. Then it will go to my lock screen, then back to the no icon screen - back & forth until I reset my phone.
Any idea what is causing this & how to fix it?
I have an LG Stylo 3...no new updates, no new apps. And all installed apps are from Google Play store.
Thanks
Thanks
