Touch wiz continuously stops while using my Samsung Galaxy Tab Pro 12.2 What can I do or is there another launcher that's
comparable or in this case better
Welcome to Android Central! Try going to Settings>Apps, select TouchWiz, and clear its cache. If that doesn't help, then you can try clearing its data, but this will wipe your homescreens, and you'll have to set them back up again.
