1. ozstar's Avatar
    HI
    Have a Note 8 and it says it is full.
    I have connected it to my Win 10x64 2004 Build 19041.804
    When I have done this before I see all the files on the Galaxy and just copy/move to the PC then delete them on the phone.
    Now I can't do this is some areas. I am shown an icon like a HD with the Win10 window on it.
    I need to clean out the phone how can O do this please.
    oz
    02-22-2021 12:37 AM
  2. Kizzy Catwoman's Avatar
    Hi there. Try downloading the Your Phone app from the galaxy store.
    https://apps.samsung.com/appquery/ap...oft.appmanager
    You may also need to install it on your Windows machine. This may help you to access the files on your phone.
    02-22-2021 01:49 AM
  3. B. Diddy's Avatar
    Typically, the areas that are hidden from the user are protected system directories that you shouldn't mess with. Which directories are you trying to access that you could see in the past?
    02-22-2021 10:31 AM
  1. Exporting Amazon KIndle downloads from Nexus to a PC
    By BertCoules in forum General Help and How To
    Last Post: 02-22-2021, 04:57 AM
  2. Note 9 bluetooth connection to pc
    By mcgigglez in forum Samsung Galaxy Note 9
    Last Post: 02-21-2021, 03:22 PM
  3. Note 9 bluetooth connection to pc
    By mcgigglez in forum General Help and How To
    Last Post: 02-21-2021, 03:20 PM
  4. Ringtone keeps changing back to the original default tone
    By ags2 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 02-21-2021, 02:32 PM
  5. How to change only one apps preferred texting method
    By Lbretep86 in forum Ask a Question
    Last Post: 02-21-2021, 10:40 AM
