Hi all,
I'm new here
I have a question regarding notification on status bar. Most applications' notification have been set to on but it doesn't show any notification icon on the top left status bar. In the status setting, it says app A has sent notification for example 3 minutes ago but it doesn't show in status bar. Whatsapp is fine but most apps have the problems. I have tried almost everything, turning off data saver, battery saver set to off but it doesn't make any difference. Currently using Samsung A50S running Android 10. Any thoughts would be appreciated. Thanks
I'm new here
