1. AndyGee170895's Avatar
    I have an old HTC 10 that has not been used for a couple of year, but need to get some photos from it. It is in download mode when turned on but the volume buttons don't work to navigate up and down, so can only select system info. Anyway to get past this to reboot phone? Also tried to get the photos off but when plug phone into computer it is not recognised
    03-08-2021 03:09 AM
  2. mustang7757's Avatar
    Hi welcome to AC !
    Are the buttons physically broken? Also did you use Google photos they might be backed up .
    03-08-2021 07:33 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! It does sound like the Volume buttons might be faulty. You could try swabbing them with rubbing alcohol, in case there's some residue caught in there that's interfering with their function.
    03-08-2021 01:14 PM
  1. New login to Instagram from GooglePlusBot on Linux
    By Jaba Chutlashvili in forum Ask a Question
    Last Post: 03-10-2021, 01:31 PM
  2. How to Keep YouTube From Refreshing
    By anewbie2 in forum Ask a Question
    Last Post: 03-08-2021, 07:35 PM
  3. Google Chrome search results, pics not loading
    By Rashnar444 in forum General Help and How To
    Last Post: 03-08-2021, 12:58 PM
  4. how to unlock HTC One M8 without factory reset.
    By nebulaastra1 in forum Ask a Question
    Last Post: 03-08-2021, 07:18 AM
