1. Icecoldsteele's Avatar
    Hello! My ulefone 6s battery doesn't work when phone isn't on. I'll plug my charger in and nothing will happen. It'll shut down because low battery and then it will start charging, then my phone will turn on and then stop charging, this will loop.
    If anyone can tell me how to fix that is great!
    03-17-2021 11:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already tried a different charging cable/plug? If the same thing happens, then it could be a problem with the battery, charging port, or motherboard. You'd probably have to bring it to a repair shop.
    03-17-2021 11:55 PM
  3. Icecoldsteele's Avatar
    Yes, I've tried a different plug in.. So I will have to go to a repair shop? Are you aware if it will cost money or be free?
    03-18-2021 12:06 AM
  4. mustang7757's Avatar
    Hi, welcome to AC!
    Make sure no dirt build up is in the charging port .
    03-18-2021 12:46 AM
  5. B. Diddy's Avatar
    That depends on if it's still covered by warranty. When did you buy the phone (and did you buy it new, refurbished, or used)?
    03-18-2021 02:09 AM
  1. Not including chargers is potentially dangerous
    By EnthalpiousKitten in forum General News & Discussion
    Last Post: 04-09-2021, 08:14 AM
  2. Phone won't fast charge
    By Slowcharge12 in forum General Help and How To
    Last Post: 03-17-2021, 05:28 PM
  3. Speakers don't work on first call but do on second
    By Slizza786 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-17-2021, 12:11 PM
  4. Search Not Working in Messages App
    By TipsyMcStagger in forum Ask a Question
    Last Post: 03-17-2021, 08:42 AM
  5. PS5 controller not working on S21 Ultra?
    By BigMosley in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 03-16-2021, 05:51 PM
