1. Dannyblaq's Avatar
    Pls my android phone gets system cool down warning before shutting dowon automatically. what can i do to stop this. thanks.
    04-10-2021 04:00 AM
  2. mustang7757's Avatar
    Hi, welcome to AC!
    Which device?
    04-10-2021 10:25 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is it actually heating up significantly while you use it, or does it seem to be a false alarm?
    04-10-2021 10:54 AM
  4. belodion's Avatar
    When using it how?
    mustang7757 likes this.
    04-10-2021 03:22 PM
  5. stevenjb2020's Avatar
    I shoot with my Pixel outside in direct on sunlit hot weather and the phone sometimes would shut down
    belodion likes this.
    04-10-2021 06:27 PM
  6. B. Diddy's Avatar
    Good point -- another common situation would be using the phone on a car mount in direct sunlight. The combination of the direct sunlight heating up the phone and actively using the phone for navigation can really cause the internal temp to rise, forcing a shutdown for safety's sake.
    04-10-2021 06:54 PM
  7. Poolman55's Avatar
    I had a Droid X that would do that in my car. It was aggravating.
    04-10-2021 10:33 PM
  1. Replies: 3
    Last Post: 05-05-2021, 03:48 AM
  2. Why is my S20 doing this?!!!!
    By Chris9181 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 04-16-2021, 10:38 AM
  3. Ulefone Power 3 (Android 7.1.1) and Android Auto - it doesn't work
    Last Post: 04-10-2021, 10:58 AM
  4. Replies: 2
    Last Post: 04-10-2021, 10:27 AM
  5. How can unlock my apps in hidden apps and i have forget my patternn
    Last Post: 04-10-2021, 01:15 AM
