1. 1BigWayne's Avatar
    I'm having an issue where any time I'm using the pop out window feature so I can browse othe apps while watching YouTube (or Twitch for that matter) the window always appears in the bottom right of my screen where my 'back' and 'home' button are and it's layered under them.
    Anytime I try and move it from that spot and try to slide it up, it acts as though I'm trying to remove it and disappears. It will then reappear later when I slide to different apps and screens.
    The phone is a Samsung Galaxy S 10e. Does anyone know how I can fix this?
    04-12-2021 03:55 AM
  2. mustang7757's Avatar
    Hi, welcome to AC!
    You can't drag it around the screen?
    04-12-2021 09:19 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! On my Pixel 3 XL, when I start to drag the PiP window, a little X in a circle shows up at the bottom center of the screen. If I drag the window anywhere near that X, it goes away. So when you drag the window, make sure you drag it straight up​ to avoid that X, and see if that works better.
    04-12-2021 12:38 PM
  4. 1BigWayne's Avatar
    Hi, welcome to AC!
    No, not at all
    04-13-2021 06:22 AM
  5. 1BigWayne's Avatar
    Whenever I try to drag it up it just slingshots back down the X and disappears
    04-13-2021 06:23 AM
  6. Grabber5.0's Avatar
    That's really weird!
    04-13-2021 09:02 AM
  7. mustang7757's Avatar
    No, not at all
    Long press youtube then tap info , scroll down to appear on top and picture over picture , are they enabled ?Youtube pop out window is always in the bottom right of my screen, how do I fix this?-screenshot_20210413-102144_settings.jpg
    04-13-2021 09:23 AM
  8. B. Diddy's Avatar
    Try wiping the cache partition: https://www.t-mobile.com/support/dev...ng-galaxy-s10e
    04-13-2021 11:20 AM
  9. 1BigWayne's Avatar
    Long press youtube then tap info , scroll down to appear on top and picture over picture , are they enabled ?Click image for larger version.
    Yes, both are enabled
    04-14-2021 03:04 AM
  10. 1BigWayne's Avatar
    This fixed my issue, thank you!
    mustang7757 and B. Diddy like this.
    04-14-2021 09:38 AM
  11. mustang7757's Avatar
    Glad B. Diddy clear cache worked, also in future can force stop or clear data and force stop the app also ,it resets it .
    04-14-2021 09:44 AM
  12. stevenjb2020's Avatar
    Use NewPipe from FDroid
    04-16-2021 01:43 AM
  1. Why is my tablet making a funny noise and then it turns off
    Last Post: 04-12-2021, 12:36 PM
  2. How to use with Citrix
    By bartjunited in forum HP Chromebooks
    Last Post: 04-12-2021, 12:29 PM
  3. Running windows apps
    By bartjunited in forum Acer Chromebooks
    Last Post: 04-12-2021, 12:19 PM
  4. how do i set my samsung s9 to auto power up when plugged in
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 04-12-2021, 09:21 AM
