Windows 10 does not include Media Player, but I think it can be downloaded (free) from the MS store.
I have used VLC for a while, but mainly for watching movies on DVD. That was before my current build (about a year ago) which does not include an optical drive. I have a stand-alone DVD/Blu-Ray player and have Netflix and Amazon Prime streaming.
For ripping in Windows, I use mainly EAC, but have used MusicBee and iTunes.
I have some new info on the hiccup issue:
I ripped two 30 minute tracks from a CD into .wav files in Windows using iTunes.
I ripped at 44.1Khz 16 bits 2 channels (stereo).
Then I uploaded the two files to my phone and played them using the default player (not PowerAmp).
During the first track, I had no hiccups.
On the second track, I had no hiccups, but towards the very end of the track the audio started getting weird. It sounded like a rapid pulsing, or beat.
I think this was caused by a problem with the sample rate of 44.1KHz vs the playback rate, which is probably a variable rate.
So I will try re-ripping using the default settings (auto sample rate) and see what happens.
It would be interesting if the hiccups return when I use the default sample rate, but I'm only speculating at this point.
Oh, and I made one other change when I listened this time: I used the wired headphones.
So I need to stick to making only one change at a time, or I'm going to lose track of this whole experiment.
