Hey guys;
I know this has been an ongoing issue for some Android owners. I am at my wits end to figure out a solution.
My phone is: Moto G7 Optimo Maxx Tracfone.
SD Card: Samsung EVO Select 256GB MicroSDXC UHS-I U3 100MB/s Full HD & 4K UHD Memory Card.
I am now using flac for music. Was using ogg Vorbis before.
When I switched to flac, I did not have any expectations that this would fix the hiccup problem - and it did not.
I have had some success with disabling / uninstalling some apps I wasn't using, and I thought might be causing the hiccups, but they haven't stopped - although the frequency of hiccups seems to have dropped.
WiFi seems to have some effect. When turned off, lfrequency of hiccups seems lower, but not zero.
Now, this hiccup thing occurs on all headsets - wired or bluetooth.
It also occurs with two different music players I have: Poweramp 3.x (licensed version) and the built-in Android player (don't know the name of it).
As for the apps I uninstalled or disabled:
Waze, NOAA Weather app, Lightning Tracker app, Google Earth, and there were several more.
I have also disabled the Android FX app, which for some reason I had switched on - don't need it with Poweramp's EQ.
The hiccups are very brief - a small fraction of a second, but it drives me mad!
I am getting to the point where I may buy a dedicated music player (with bluetooth), but if I do that, then I won't be able to receive phone calls while out running, since the only headphones I own that have multipoint are the Bose QC 35 II, which are not outdoor headphones. I normally run with JBL/UA Train Wireless, or Jabra Elite Active 75T.
I had this same issue with my last phone - LG Fiesta II (Tracfone) with Android 7, so I know it's not a phone thing.
Any ideas?
Thanks
Ultrarunner
Any ideas?
Thanks
Ultrarunner
