1. Jockyspider's Avatar
    Hi I saw this on YouTube what the score with these and can you check through settings instead of typing these in.
    *#61# call forwarding
    *#62# call forwarding when unreachable
    *#76# if your phone is busy or you reject call
    05-12-2021 09:16 PM
  2. hallux's Avatar
    Those settings trigger flags with the carrier to implement the feature, the phone itself doesn't control it.
    05-13-2021 06:48 AM
  3. Jockyspider's Avatar
    Oh ok so should I just leave it then. Am getting all my calls and voicemails. Did factory reset before I used it after a family member give it to me.
    05-13-2021 12:34 PM
  4. Jockyspider's Avatar
    And how would I know if it was being used maliciously
    05-14-2021 05:56 PM
  5. B. Diddy's Avatar
    Those kinds of codes can't be used maliciously. If they could be used maliciously, it would be a ridiculously huge security hole. That wouldn't happen. Don't worry about it.
    05-14-2021 05:58 PM
  6. Jockyspider's Avatar
    Thanks for the advice
    06-09-2021 11:16 PM
  1. Sim card lock code
    Last Post: 05-12-2021, 02:31 PM
  2. Micro Game - First Game Ever - Cheat Code Trainer
    By dadude2607 in forum Android Apps
    Last Post: 05-12-2021, 07:51 AM
  3. I just got my qlink sim card there is a sim lock how do i get that code
    Last Post: 05-11-2021, 11:02 AM
  4. I need my code to sim puc my phone is locked
    Last Post: 05-03-2021, 03:20 PM
  5. PUC CODE for Qlink to unlock network
    Last Post: 04-24-2021, 11:06 PM
