1. DrMomz's Avatar
    If you have a tempered glass screen protector on & you're having a problem getting yr fingerprint to register (or to work after its registered) try moistening the tip with a miniscule bit of lotion, (or run yr fingertip over your face to pick up the tiniest dab of oil). I found that when my fingertip was too dry, it wdn't register. When l did the above, my print registered on the 1st or 2nd try (instead of maxing out!)
    06-09-2021 03:52 PM
  2. B. Diddy's Avatar
    Thanks for the tip! I moved this from the Introductions forum to the General Help forum, since it's more appropriate here.
    06-09-2021 10:15 PM
  3. mustang7757's Avatar
    06-09-2021 10:26 PM
  4. B. Diddy's Avatar
    Duplicate threads merged.
    mustang7757 likes this.
    06-09-2021 10:53 PM
  1. Fingerprint option Missing
    Last Post: 06-09-2021, 11:20 PM
  2. My lg K30 says invalid SIM card. How can I fix this?
    Last Post: 06-06-2021, 01:07 PM
  3. how to fix a LG android phone keybord
    Last Post: 06-02-2021, 10:28 PM
  4. Why is my fingerprint sensor not working at all.
    Last Post: 06-01-2021, 10:41 AM
  5. Fixing "No recently used apps" problem.
    Last Post: 05-28-2021, 10:15 PM
