1. joey2421's Avatar
    I have the S7 Slim and Ive been trying to find a good keyboard for it to use it to take notes. Anybody know of a keyboard that would work with this one, either with the micro usb port (and adaptor if necessary) or via bluetooth? Any help would be much appreciated, thanks!
    07-12-2011 03:58 PM
  2. yodatom10's Avatar
    I believe best buy has one that will do what u want.
    joey2421 likes this.
    07-13-2011 05:15 AM
  3. joey2421's Avatar
    I looked on best buy but they only really had keyboards for ten inch tablets. Then I saw those portfolio-style keyboard cases on Amazon, does anyone have any experience with them, or know if they work? Thanks in advance
    07-16-2011 03:06 PM
  4. Sharks1's Avatar
    http://www.androidtablets.net/forum/huawei-ideos-s7-accessories/5684-bluetooth-keyboard-s7-paired-receiving-keypresses-but-no-apps-see-them.html
    02-15-2012 06:10 AM
  5. Setac's Avatar
    you mast have otg cable and than every keyboard is goog i by for me chepest litle keyboard for 3$ and its pefect
    Sent from my IDEOS S7 Slim using Tapatalk
    02-26-2012 01:56 AM
