1. Dacker9's Avatar
    Hi
    I am a novice and would appreciate some advice please
    I have a Samsung note 4, but it is running as an s8 plus
    it was problematic so I did a factory reset hoping that it would then restart as a note 4, but a Dr Ketan root failed message came up.
    As far as I know, it is still running as an s8 plus.
    phone settings
    About Device
    Device name galaxy note 4
    Model number SM-G955F which I believe is s8 plus
    The question I am asking is, how can I reset it to run as a Samsung note 4
    Thank you
    Kind regards, Dacker
    06-12-2021 01:11 PM
  2. mustang7757's Avatar
    Hi welcome to AC!
    I'm confused by what you said here ?
    "I have a Samsung note 4, but it is running as an s8 plus"
    How can this be ?
    Dacker9 likes this.
    06-12-2021 01:27 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Did you root the phone at some point and install a custom ROM? Or did you get this phone from someone else who rooted it?
    Dacker9 likes this.
    06-12-2021 01:47 PM
  4. Dacker9's Avatar
    Hi and thanks for your replies
    I bought this note 4 off someone else and they set it up as a s8 plus phone, but the phone has issues so I factory reset it, but it still seems to be running as a s8 plus. The phone is definitely a note 4 because I have had one before.
    When I go into settings
    About device
    Model number shows SM-955F which is s8 plus
    I want to reset it so it runs as a note 4 and not s8 plus. Thanks
    06-12-2021 03:39 PM
  5. mustang7757's Avatar
    About device
    That's not possible , the s8 plus doesn't have a spen and Note 4 is much older phone then s8 plus.
    Where did you buy if from ? They lied to you .
    Dacker9 likes this.
    06-12-2021 03:58 PM
  6. Dacker9's Avatar
    Thank you
    I bought the phone used off ebay, it was stated as a Samsung galaxy note 4 phone, which it is,
    but in the phone settings, it states model number SM-G955F which is s8 plus
    So the phone is a note 4 but operates like a s8 plus
    The phone has some temperamental issues so I just want to factory reset it to operate as a normal note 4 phone, but after I factory reset it, it still remains to operate as an s8 plus phone so must have some sort of s8 plus root
    I hope that makes sense because I am a novice, thank you
    06-12-2021 04:51 PM
  7. B. Diddy's Avatar
    Can you take a picture of the phone from a few different angles and post them here? It sounds like someone took a Note 4, rooted it, and installed some kind of custom ROM to make it look like an S8. Or maybe someone replaced the motherboard of a Note 4 with an S8 motherboard? That would seem pretty unlikely, though.
    Dacker9 likes this.
    06-12-2021 05:27 PM
  8. mustang7757's Avatar
    Thank you
    Which phone is yours out of these 2 pictureAdvice on factory reset please, Samsung note 4 but running with s8 plus-refurbished-original-samsung-galaxy-s8-plus.jpgAdvice on factory reset please, Samsung note 4 but running with s8 plus-download.jpg
    Dacker9 likes this.
    06-12-2021 05:28 PM
  9. Dacker9's Avatar
    Thank you
    I’ve got pics of the phone, but I don’t know how to upload them here sorry
    From your pics, my phone is the one on the right with the pen, thank you
    06-12-2021 05:47 PM
  10. mustang7757's Avatar
    Thank you
    Ok you have a Note 4 , with some custom ROM on it
    Dacker9 likes this.
    06-12-2021 05:49 PM
  11. B. Diddy's Avatar
    Here's how to post images: http://forums.androidcentral.com/gen...d-central.html. (Ignore the steps about how to take a screenshot.)
    It's best to do it on the forum site on your computer browser, or on the Tapatalk-based AC Forums app. The main Android Central app doesn't allow users to post images in replies, for some reason.
    Dacker9 likes this.
    06-12-2021 05:57 PM
  12. Dacker9's Avatar
    Thank you for your replies
    Yes it does seem that I have a Samsung note 4 phone with a custom ROM that relates to the s8 plus
    I would leave the phone as it is, but the phone has some problem instability issues so I would like to just be able to factory reset it back to a normal note 4.
    If anyone has any ideas how this can be done then that would be great although I am a novice at these things.
    It is late here now in the UK so I will view any possible replies in the morning.
    Thank you all very much for your kind help, best wishes to you all.
    mustang7757 likes this.
    06-12-2021 06:27 PM
  13. mustang7757's Avatar
    Best thing to do is flash the stock firmware with Odin tool , download from XDA Forums and try sammobile for the firmware if don't find at XDA
    Dacker9 likes this.
    06-12-2021 10:15 PM
  14. Dacker9's Avatar
    Thanks very much for your kind help
    06-13-2021 05:22 AM
  15. Kizzy Catwoman's Avatar
    If you get the software suggested then @mustang7757 is good at talking you through the process
    06-13-2021 05:53 AM
  16. mustang7757's Avatar
    Yes definitely
    06-13-2021 10:10 AM
  17. Dacker9's Avatar
    Hi
    I have tried to follow instructions, but I only got so far so I have decided, because I am somewhat of a novice that I will pay for the phone to be rectified or sell it as it is, with discription of faults.
    I am very grateful for the kind help that you all gave me and felt I should give you this update, thanks
    mustang7757 and B. Diddy like this.
    06-14-2021 04:32 PM
  18. mustang7757's Avatar
    Hi
    Ok Your welcome !
    06-14-2021 06:59 PM
  1. "tge" instead of "the" - Help please.
    By GretScot in forum Ask a Question
    Last Post: 06-13-2021, 10:14 AM
  2. Can anyone tell me what this is and how to get rid of it? Samsung Galaxy S7 edge
    Last Post: 06-12-2021, 03:01 PM
  3. Replies: 0
    Last Post: 06-12-2021, 10:38 AM
  4. How to recover samsung account?
    Last Post: 06-12-2021, 09:40 AM
  5. What is in android 11 for a Samsung s5e tablet?
    Last Post: 06-12-2021, 09:14 AM
