Originally Posted by
Autolooper It charges, but the USB menu doesn't appear. I'm concerned something installed is preventing it from appearing but I don't know of a way to verify that.
Might be a bent data pin or just a faulty USB port altogether. Could always do a factory reset to rule out software after trying Diddys' suggestions above. If that doesn't fix it then take it to your local repair shop and see if they can replace the USB port.
