Galaxy J7 2017 / SM-J730F/DS Display from A dropped small damage to even big
Alin Tecsan
7
Hi , i have problems about a phone which my dad owns an Samsung Galaxy J7 2017 Edition . The phone was dropped by an accident yesterday and the damage was small i can touch anything except the part where was dropped like a black hole and today after overnight something spreaded the damage without to touch even it would look like this :
The problem is i had to fix the damage a new display but the price if expensive i had to find at second hand one , is really important to him to have his device back i borrowed to him my Huawei P10 Lite from my collection and battery draining fast after an use :( The Situation should be solved.
I'm not really sure what you're asking, but it looks like it needs a new screen as you noted. There's not much we can do for you through the forums.
I would look on Google for mobile phone repair service. Although the repair may be more expensive than the cost of a replacement screen.
Are you asking how to replace it yourself? If you're not experience with that, I would strongly recommend against trying -- you could easily render the phone completely dead if you don't know what you're doing.
Is there a screen protector on it?
TyeFighter
