Originally Posted by
Kizzy Catwoman You can now download zedge ringtones as mp3
The last time I used the app yes and no. So the work-a-round is that you look up the RT you want on Zedge, download it by setting it as whatever, notification ringtone alarm, and it becomes the default for whatever category you set it for. Now you have the RT on your device and can set it for an individual contact, which is what I usually want them for, or use it anywhere you want. Then you have to go back and change your default back to whatever you want the default to be.
As far as a straight download, where the RT is just saved and accessible, no, Zedge seems to have stopped that. Again, around the time I began noticing this, every time I opened the app I was hit with 1 sometimes 2 or 3 offers to upgrade to the paid service. I think they always offered a paid version but it seemed they were really pushing users to upgrade. Which is why I kind of felt like they had taken away the pure download and made that a premium feature, along with whatever else you could do in the paid version. Wallpapers where the same. You could download anything as long as you set it from the app but couldn't straight download them for use later or use in another app or whatever. Not sure if the wallpapers worked the same way because I wasn't really using Zedge for anything other than RTs.
But hey, that was ~1 year ago. Anything could have changed since then and it may have actually been a bug.
