1. dangerousfen's Avatar
    My Nokia 7.2 running Android One toasted today and was refunded by Argos.
    I'm considering the Redmi Note 10 Pro as a replacement but know nothing about MIUI. SO I'm reaching out to you Xiaomi users for advice. i.e. do Android 11 gestures work? Is the UI far removed from what I'm used to? Can I install Nova to give me some normality?
    What are the software updates like?
    Your help would be appreciated.
    07-28-2021 06:51 PM
  2. Kizzy Catwoman's Avatar
    From a post I saw on Telegram, some people have said MiUI doesn't work with gestures if you use a third party launcher, but does with stock launcher. This is from one of the Niagara Launcher channels.
    Here is a link to an article about it
    https://piunikaweb.com/2020/12/19/xi...rty-launchers/
    dangerousfen likes this.
    07-28-2021 10:26 PM
  3. dangerousfen's Avatar
    Thanks for that Kizzy. So it appears that you have to use the stock launcher. I just am a bit concerned regarding the use of MiUI after a long time using Android One.
    Updates are also an issue I believe.
    07-29-2021 02:17 AM
  4. dangerousfen's Avatar
    Well, after much Googling, I've decided to pull the trigger on the Xiaomi Redmi Note 10 Pro. It's quite a beast of a phone for its price.
    I always stated that I would never buy a Chinese product but I really can't pass up this bad boy.
    07-30-2021 06:17 PM
  5. cnixon52's Avatar
    Yes they can
    How did it go - sorry I wasn't here in time to save you!
    08-14-2021 05:37 PM
  6. dangerousfen's Avatar
    Yes they can
    That's ok.
    I've been using my new Redmi Note 10 Pro for well over a week now and just love it. It's a beast for the price.
    08-15-2021 06:26 PM
  1. Random stock looking images in my Samsung S20 photo gallery, help!
    Last Post: 07-28-2021, 09:01 PM
  2. Replies: 3
    Last Post: 07-27-2021, 04:33 PM
  3. android 11 contact with location sharing
    By spotsheffield in forum Ask a Question
    Last Post: 07-27-2021, 12:50 PM
  4. Thanks for the help...cannot log in to forum
    By Android Central Question in forum Site Feedback & Help
    Last Post: 07-26-2021, 03:03 PM
  5. Thanks for the help...cannot log in to forum
    Last Post: 07-26-2021, 12:27 PM
