1. Tepacana's Avatar
    I'm using a Galaxy A20e with Android 11, I used to be able to transfer files from my PC to my phone whenever it was plugged in and unlocked as normal. Using the same cable, I now can't change the connection type to file transfer in the notification. That now takes me to the power usage settings. I've activated the developer settings to allow me to change the default USB state to file transfer, but this does nothing, and I can't tap on the notification to try and change the connection type, because that jsut shows me battery power now.
    Any help would be fantastic, thanks.
    08-28-2021 08:11 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you tried a different cable? Sometimes a cable's data transfer wires can become faulty.
    08-28-2021 12:40 PM
  3. Laura Knotek's Avatar
    Have you tried a different USB port on your computer?
    Thomas_George and mustang7757 like this.
    08-28-2021 07:21 PM
  4. Tepacana's Avatar
    Hi, I've tried both of these things, I was going to try using a different pc today and see if that's any different, trying both wires and different ports on that too.
    08-29-2021 10:33 AM
  5. B. Diddy's Avatar
    Make sure the USB ports for the phone and the PC are completely clean. Use a can of compressed air to blow them out, and a dry toothbrush to scrub them.
    Laura Knotek likes this.
    08-29-2021 12:21 PM
  6. Tepacana's Avatar
    Tried cleaning out both ports I tried on each computer and both cables I tried, along with the port on the phone. Did so using the dry toothbrush thing and got a thin pin to get tiny bits of debris out, still no luck on either pc or using either cable unfortunately. Starting to think it might either need a new sort of cable I don't have or that something software-side isn't quite co-operating.
    Again, thanks for the replies.
    08-29-2021 06:57 PM
  7. B. Diddy's Avatar
    Were you able to test it on another PC?
    08-29-2021 07:04 PM
  8. Tepacana's Avatar
    Oh yeah, I forgot to mention it, didn't seem any different on the other PC either. Still defaulted to cable charging and can't tap on the notification to change it, takes me to the power settings of the phone. It doesn't appear on either file explorer or device manager on either PC.
    08-30-2021 07:55 AM
  9. B. Diddy's Avatar
    Can you show us a screenshot of that notification? http://forums.androidcentral.com/gen...d-central.html
    08-30-2021 12:06 PM
  10. Tepacana's Avatar
    I've got a screenshot of the notification itself, I can send one of the thing it brings up after I tap on it if that helps.
    09-01-2021 09:13 AM
  11. B. Diddy's Avatar
    Hmm, there should be an Android System notification for the USB connection type. I don't think this will help, but go to Settings>Apps, tap the Filter button and toggle on Show System Apps, and select Android System. Then select Notifications, and make sure everything is toggled on. On my A32 5G, the toggle for USB Connection is permanently on (greyed out), so I'm assuming that will be the case for you, but who knows, it might be different for some reason.
    09-01-2021 12:15 PM
  12. Tepacana's Avatar
    Yeah, my USB connections listing in the notifications screen you sent me too is also locked at being on.
    I did have an idea, I could move everything I want to keep on my SD card, remove it and factory reset the phone by itself, that might shake out some old software from compounded system updates.
    Obviously going try that after everything else, to avoid the possibility of not having moved something I wanted to keep and then not being able to transfer it from the PC.
    09-01-2021 12:34 PM
  13. B. Diddy's Avatar
    Try wiping the cache partition first, which won't affect any of your personal data: https://www.t-mobile.com/support/dev...ung-galaxy-a20
    09-01-2021 12:50 PM
  14. Kizzy Catwoman's Avatar
    You can toggle the file transfer mode as default in developer options. Go to settings, about phone and tap on build number 7 times to open the developer options menu. Under developer options you can set the USB connection type to file transfer.
    09-01-2021 01:50 PM
  15. Tepacana's Avatar
    Thanks for the continued replies!
    I've tried wiping the cache partition, that didn't seem to have an effect unfortunately, and changing the default bluetooth settings was one of the first things I tried, I also tried that again after wiping the cache and it was still set to file transfer. I also tried switching it to charging only and back again, still no luck unfortunately.
    09-05-2021 09:20 AM
  16. B. Diddy's Avatar
    Hmm, might be getting down to the nuclear option of factory reset.
    Longshot, try going to Settings>Apps, tap Menu, then Reset All App Preferences.
    09-05-2021 10:42 PM
  17. Motoman43's Avatar
    So below is how I transfer files in either direction between MotoG7Power phone Android 10, and USB flash stick.
    My PROCEDURES:
    USB FLASH DRIVE -TO-PHONE (verified procedure on 9/5/21:
    On my Moto phone:
    1. Connect a USB flash drive (containing PC files) to transfer to phone.
    2. Swipe down from home page.
    3. Tap USB drive (or name of USB drive e.g. PNY)
    4. Tap desired folder or file (e.g. desired pic) Verify check mark.
    5. Tap upper right (three dots) to Move or Copy selected folder or file from step #4.
    6. Tap Move to or Copy to (Download or other Folder)
    7. Tap Copy
    8. Tap ‘files’ to verify (see transferred files/pics in Download or other folder).
    PHONE-TO- USB FLASH DRIVE (verified procedure on 9/9/21/0
    My verified procedure on 9/9/21
    On my Moto Phone:
    4. Tap desired folder or file (e.g. Camera pics) Verify check mark.
    6. In upper left three bars, tap USB drive (or name of USB drive e.g. PNY)
    7. Tap copy.
    8. See copy or move progress text.
    Hope this helps someone.
    09-09-2021 05:48 PM
  1. Surprised not many users
    By JOHNGAETANO in forum Samsung Galaxy Z Fold 3
    Last Post: 08-29-2021, 08:03 PM
  2. Bluetooth not working only on calls
    Last Post: 08-28-2021, 01:30 AM
  3. My cell wont work
    Last Post: 08-27-2021, 09:34 PM
  4. Why are my contacts not transferring?
    Last Post: 08-27-2021, 05:14 PM
  5. Transfer Whatsapp data from Windows phone to Android phone
    Last Post: 07-14-2019, 09:50 AM
