Where they truly MMS or were they sent via iMessages? Since iMessages handles media differently they probably won't transfer since they don't conform to MMS standard. An app meant to handle regular messaging won't be able to import iMessages media because they don't genetically match. So to speak. iMessages doesn't have the size restrictions that regular messaging does and even high res pics have a hard time being transferred over MMS.
I found this result which sounds too simple for you not to have found it also but JIC FYI...
https://www.google.com/url?sa=t&rct=...jZoerfxI2_zEuP
My search also popped up some YouTube videos so you might try YT as well.
