Im not sure if available for that android version but your correct where its locatedWelcome to the forums. I'm not sure if this option is available in Android 9 or only in 10+. Enable Developer Options tapping 7-10 the Build number in About phone and after this search for "Tiles" in the settings. If you get this option you can create a quick settings tile to switch the sensors off and on.
Tell us how it goes.View attachment 337148View attachment 337149View attachment 337150
Yup, it's possible that this option started with Android 10.Im not sure if available for that android version but your correct where its located
Possibly im not 100%Yup, it's possible that this option started with Android 10.
