1. nobrowser's Avatar
    I have the Sunshine T1 tablet (aka Cloudmobile?) running Android 11. It works quite well considering what I pad for it , even the battery life isn't so bad. But the charging behavior drives me nuts. It isn't just *slow*, but crazy nonlinear. I mean, it's slow but steady from 0 to about 85%, and very quick from 90% to full, but that stretch between 85 and 90 takes *at least* an hour, probably more.
    The system seems to consider 90% as close to full because there is an option to turn off the battery saver mode when it gets there. So I would like to reach at least that point before starting to drain it again.
    Is this perhaps normal for some batteries? Or am I doing something wrong? I always put it in airplane mode when charging. I also tried different cables and charging locations, neither makes a difference.
    09-20-2021 02:20 PM
  2. SpookDroid's Avatar
    Depends on the charging method you're using, but this is usually normal behavior. Charging speeds are faster on the low-mid battery range and begin to slope down as it reaches full capacity.
    Laura Knotek likes this.
    09-20-2021 03:08 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree with SpookDroid, although I'm not sure why it goes quickly from 90% to 100%. It might be a quirk of the firmware's battery reporting software.
    09-20-2021 03:41 PM
  1. Just picked up the Galaxy watch 4 yesterday
    By amyf27 in forum Samsung Galaxy Watch 4
    Last Post: 09-20-2021, 08:57 AM
  2. Can You Break A Phone From Just Putting Weight On It?
    By LBO6051 in forum Ask a Question
    Last Post: 09-19-2021, 08:59 PM
  3. Flip z 3... Not able to change the ringtone sound...???
    By Android Central Question in forum Samsung Galaxy Z Flip 3
    Last Post: 09-19-2021, 08:57 PM
  4. Flip z 3... Not able to change the ringtone sound...???
    Last Post: 09-19-2021, 08:09 PM
  5. gallery n camera not working
    Last Post: 07-12-2017, 02:51 AM
