Random was able to do split screen on same you tube app anyone know how cant replicate ?
anon(10753934)
381
Using pixel 4 11r was able to split screen the you tube app with the you tube app. Anyone know how this was possible ?Screenshot_20211016-194509.jpg
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
The one on the bottom is the YouTube website on the browser -- you can tell by the Explore button. The app doesn't have those.
anon(10753934)
381
Hey fellas cause of the the explore tab bottom right ? Its a nova setting. Im sure its the app it has shorts,Added capabilities and ability to cast to unlike the browser.
Also fellas thats the Youtube app below browser above.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
Oh yes, you're right. The website has the Explore option in the lower navigation buttons.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Yes it is play store updated to but device doesnt register it & still stuck on 01/10/21 Oct update not sure if that has a effect.
Version 27.5.14-21 [0] [PR] 401824934 running that.
Can change and modify build number at will.
Can see when you get next play store update or Android 12 if it gets fixed
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
So the First ss is youtube app twice yeah ?
Correction too its just split screen the two bars.
No, what I'm saying is that one of them is the YouTube app, and the other is your browser on the YouTube website. The mobile website looks quite similar to the YouTube app interface.
samyblaze
