1. Gtom66's Avatar
    The problem is that video is slow from internet browsers only on my Android11 Xperia 10III. If streaming comes trough YouTube or video is recorded everything is fine. Mobil data traffic is good enough. Seams that somewhere system settings is wrong but can't find exactly what. Hope for support.
    11-24-2021 05:52 PM
  2. mustang7757's Avatar
    Hi welcome to AC!
    You experience this both wifi and data?
    You use a VPN?
    Laura Knotek likes this.
    11-24-2021 09:25 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I assume the browsers are all up to date in the Play Store?
    See what happens if you uninstall all updates to Android System Webview. Sometimes a recent update to that system app can cause glitches in certain devices.
    11-25-2021 12:53 AM
  4. Gtom66's Avatar
    Slow video/audio performing in all data connections but only trough browsing - Chrome, Oppera.... If I open YouTube directly than all video and audio is perfect and records in the phone storage as well.
    I don't use VPN
    11-25-2021 04:04 AM
  5. Gtom66's Avatar
    Please provide system path where to uninstall updates to Android System Webview
    11-25-2021 04:08 AM
  6. Smokeaire01's Avatar
    In Play Store do an uninstall.
    11-25-2021 05:18 AM
  7. Gtom66's Avatar
    I did so, but without any improvements. Find that even audio podcasts sounds slow and jerking. Seams that there is some specific data flow or data processing limitations but not sure. Why does YouTube working well but other internet broadcasting not?
    Thank you so far.
    11-25-2021 07:04 AM
  8. B. Diddy's Avatar
    Does this happen on both wi-fi and mobile data?
    11-25-2021 12:39 PM
  9. Gtom66's Avatar
    I fix my issue with jerking video and audio only by streaming from browsers. It is ridiculous and unbelievable but I just switch off mono sound option in audio settings. I couldn't imagine that this can so dramatically change sound in android11.
    11-25-2021 01:25 PM
  10. B. Diddy's Avatar
    But does it matter if you're on wi-fi vs mobile data? Just trying to see if it might have to do with the kind of network you're using.
    11-26-2021 12:30 AM
  1. How can i unshrink my keyboard on a lg stylo 6?
    Last Post: 11-25-2021, 01:01 AM
  2. Pixel 6 coming from the 4a5g
    By rpdc in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 11-24-2021, 08:25 PM
  3. Replies: 1
    Last Post: 11-24-2021, 07:00 PM
  4. Pixel uses Google Voice if calling from Messages
    By RobRud in forum General Help and How To
    Last Post: 11-24-2021, 01:07 PM
  5. Replies: 1
    Last Post: 11-24-2021, 12:49 PM
