1 Attachment(s)
How can I disable a call status popup that appears after every call?
Every time my dad has completed a call, a popup screen shows up showing how long the call lasted and displaying an ad. How can this be disabled?
I have now posted a screenshot.
The phone is a Samsung, and I believe it is an S-10, but I'll have to check with him.
Re: How can I disable a call status popup that appears after every call?
Welcome to Android Central! Which phone? That could be due to some 3rd party app he installed, but some phones on some carriers also come with adware preinstalled -- Alcatel comes to mind.
Can you post a screenshot?
I have now posted a screenshot, and the phone is a Samsung, probably an S-10.
Tell him to tap that 3-dot button in the screenshot and see if it gives any additional information about what app might be responsible.
1 Attachment(s)
Originally Posted by
zapspan I have now posted a screenshot, and the phone is a Samsung, probably an S-10.
These should be the only option if you go to phone app >settings>call display while using appAttachment 339401
Thank you for your suggestion, B. Diddy. I'll try this and see what we find out.
Hi, mustang7757. The image that I posted pops up after the call is over. If I understand you correctly, you are showing options of how to view the call status during the call.
zapspan Hi, mustang7757. The image that I posted pops up after the call is over. If I understand you correctly, you are showing options of how to view the call status during the call.
Hi, i see after the call is ended, is this 3rd party phone app? The one in picture doesn't look stock
1 Attachment(s)
Welcome to the forums. That definitely looks like a third party app, maybe this Voice Recorder? It has the same icon.
Attachment 339402
I will check with my dad to see if this is in fact the Voice Recorder app. Thanks so much everyone for suggestions.
zapspan I will check with my dad to see if this is in fact the Voice Recorder app. Thanks so much everyone for suggestions.
Keep us posted [emoji106]
