Settings icon disappeared after an update to android 11
Hello everyone;
I am a new user of an Android phone. (Always had an iPhone)
I have an Umidigi A11 Pro Max
phone that just updated to android 11. After the update, the setting icon disappeared from the home screen and I can't find it anywhere. Would anyone know how to get it back. Thank you for your help
Re: Settings icon disappeared after an update to android 11
Welcome to Android Central! Bring up your App Drawer -- do you see the Settings icon there? If so, long-press it and drag and drop it back to the homescreen.
You should always be able to find the Settings icon in your Quick Settings/Notifications panel as well. Swipe down the Notification panel and look for the gear icon there. If you don't see it, then swipe down a second time to get the Quick Settings, and look for the gear icon there.
It should be in the app drawer
